Bike Finder · Trek
Trek Fuel+ EX
Trek
Fuel+ EX 2026
CurrentLightweight · TrailCurrent · 7.9/10iFreshness 7.9/10
Lightweight TQ HPR60-powered trail eMTB
Motor
TQ HPR60 · 60Nm · 350W
Battery
TQ HPR 580 · 580Wh
Travel F/R
150/145mm
Wheels
29F/29R
Frame
Full carbon
Weight
19.58 kg
Price
From £4,400
View the Trek Fuel+ EX on Trek’s site
Trek Fuel+ EX 2026
From £4,400
EMTB Forums verdict
The Trek Fuel+ EX 9.9 X0 AXS 2026 is the US brand's halo lightweight trail eMTB: a carbon ABP chassis with 150 mm of fork travel paired with 145 mm of rear, the TQ HPR60 motor at 60 Nm of torque and 350 W peak, and a removable 580 Wh TQ HPR battery. At a claimed 19.4 kg and £10,300 top-trim price, this is a serious technical contender that has rapidly built a strong forum following. With a 64.5 degree head angle and size-progressive chainstays growing 437 mm to 452 mm across five sizes (15.5"–23"), the Fuel+ EX brings Trek's class-leading Ride Aligned geometry approach to the mid-power class.
Drive system and range. The TQ HPR60 is the headline upgrade over the previous HPR50: 60 Nm of torque (vs HPR50's 50 Nm), 350 W peak and a class-leading 1.924 kg motor weight. @coregrind ran a Fuel+ EX 9.7 (HPR60) alongside a friend on a Fuel EXe (HPR50, dual 360 Wh batteries, friend 4 kg lighter) on the same trail; the Fuel+ finished with 22% battery remaining vs the friend's 12% — using 40% less battery. Strong evidence the HPR60 + 580 Wh package is a meaningful efficiency step. @Keef reports 30 miles with 4,200 ft of climbing at 90% highest power level left 13% battery — genuinely impressive real-world range for an SL-class bike. @Keef also describes the motor as "silent except when pushed hard on climbs, power delivery natural with high cadence requirement."
Geometry and handling. A 64.5 degree head angle is bang in the modern trail-all-mountain sweet spot. Reach progression is generous: 431 mm (15.5"), 460 mm (17.5"), 485 mm (19.5"), 510 mm (21.5"), 530 mm (23"). Chainstays are size-progressive: 437 mm (15.5"–17.5"), 442 mm (19.5"), 447 mm (21.5"), 452 mm (23") — Trek's Ride Aligned size-balanced rear-centre system delivers genuine geometric proportionality. Wheelbase grows 1,187 mm to 1,330 mm. Five sizes is class-competitive. The ABP (Active Braking Pivot) suspension is Trek's proven layout.
Build and value. Seven trims sit on the Fuel+ EX platform. The £4,400 5 is the alloy entry. The £10,300 9.9 X0 AXS base trim at 19.4 kg is the carbon flagship — RockShox Lyrik Ultimate fork (European pricing €11,499 per @Victorius). Between sits a strong value mid-range with £5,000–£8,000 trims. @Roaming50 on a 2026 9.7 describes the SRAM Eagle 70 transmission as "a revelation."
Community-verified strengths. Forum reception has been notably positive. @Battman85 "knew I had to have it" from launch and has documented his ownership in detail. @nickf, a former full-power Bosch Gen 4 Trek Rail owner, describes the Fuel+ feel: "gives enough support without destroying the natural sensation of pedalling with human leg effort" — a strong endorsement from someone explicitly cross-shopping the latest full-power bikes. @Yobbo has 320 miles in 8 weeks with no failures beyond an XT cassette gear-crashing issue (fixed by cassette change). The HPR60/580 Wh real-world range data from @Keef and @coregrind is the strongest single piece of forum evidence in favour of this platform.
Caveats and known gripes. Drivetrain creak has emerged as the family weakness. @Yobbo at 550 miles (880 km) developed exactly the same loud drivetrain creak the Fuel EXe predecessor had a reputation for. Stock XT cassette gear-crashing was an issue per the same rider, fixed by cassette replacement. @1234 notes the "Fuel+" naming scheme is poor for SEO and confusing for buyers. @Roaming50 reports the 9.7 is available in USA without September waitlist, but warns the LX 9.9 model has supply constraints. The 60 Nm motor is meaningfully less powerful than 120 Nm Bosch CX Gen 5 alternatives at similar money. The 580 Wh battery is more generous than 320–420 Wh competitors but smaller than 800 Wh full-power systems. @nickf wins the "balance" argument honestly — the Avinox 1000+ W feel is more dramatic than the TQ HPR60's natural assistance.
Verdict. The Trek Fuel+ EX 9.9 X0 AXS is one of the most credible lightweight trail eMTB platforms of 2026: TQ HPR60 power with a 580 Wh removable battery, Ride Aligned size-progressive geometry across five sizes, and a strong forum reception centred on genuine real-world efficiency data. It will suit riders who want the lighter, more natural ride feel of an SL-class motor with meaningful big-day range, and who value Trek's UK dealer network and Ride Aligned engineering. Buyers wanting maximum motor torque, a full 800 Wh battery, or the strongest possible spec-per-pound value should look at the Cube One77 SLX, Centurion No Pogo R5000 or Trek Rail+ Gen 5 alternatives. Production status: current.
Geometry read
Size
Descending
67
A solid all-round descender (64.5° head angle, 145mm) — capable in the rough and steep without being an all-out bruiser.
Playfulness
91
Short 442mm rear and a lighter build — easy to pop, manual and throw around.
Size balance
83
Balanced front-to-rear in 19.5" (FC:RC 1.86) — weight sits evenly between the wheels.
Technical climbing
60
Climbs well — a 77.4° seat keeps the front planted. 350W of peak power and 60Nm of torque.
Best suited toPlayful trail riding — jumps, pumps and tight, techy singletrack.
Easy to throw around; happiest when you're active on the bike.
Watch out forNo major red flags in the 19.5" geometry.
How it stacks up vs other Lightweight · Trail bikes (from 88 bikes in the database)
Weight19.58 kgabout average weight
Battery580 Wh146 Wh above average
Motor torque60 Nmabout average torque
Value for money98/100from £4,400 · most TQ HPR60 bikes ~£7,625
💬 Forum discussion
Trek Fuel Ex-e - Pairing Issue
20 replies · 9.2k views · last reply 10 months ago
Join the discussion →
“Just an update to anyone experience this issue still. A firmware update for the bike solved the issue”
— MatthewM · ♥ 3 · most-liked post
OWNERS’ REPORT
Trek Fuel EXe / Fuel+ — what owners actually know
8,181 posts · 799 owners · data through Jun 2026
8The creak complex: factory under-torque and assembly QC · typical onset: First 200km
6Integrated headset: poor cups, missing seals, and two bearing-seat frame failures · typical onset: Creaks early; the seat failure at ~2,500mi
4Lower shock eyelet play + fragile proprietary shock bolts (launch-era) · typical onset: From new (launch-era builds)
2,000 miles: 'I haven't had any issues whatsoever on the bike.
Inside: the community setup plate · numbered field notes · the used-buyer checklist.
Read the full owners’ report →
Bike geometry diagram
15.5"17.5"19.5"21.5"23"
Reach431 mm460 mm485 mm510 mm530 mm
Stack610 mm624 mm638 mm651 mm665 mm
Chainstay437 mm437 mm442 mm447 mm452 mm
Headtube Angle64.6°64.5°64.5°64.5°64.5°
Seattube Angle (eff)78.7°78.3°77.4°76.9°76.4°
BB Drop34 mm35 mm35 mm35 mm35 mm
Wheelbase1187 mm1225 mm1262 mm1298 mm1330 mm
Headtube95 mm110 mm125 mm140 mm155 mm
Standover741 mm742 mm749 mm755 mm764 mm
Front Centre750 mm788 mm820 mm851 mm878 mm
FC:RC1.721.801.861.901.94
Trims · 7
£4,400
8
£5,000
9.7
£5,500
9.8 Eagle 90
£7,625
9.8 XT
£7,625
9.8 XT Di2
£8,075
9.9 X0 AXS
£10,300
MotorTQ HPR60 · 60 Nm · all trims
BatteryTQ HPR 580 · 580 Wh · all trims
Travel F/R150/145 mm · all trims
FrameOCLV Mountain Carbon · all trims
ForkRockshox Recon Silver RL, Solo Air spring, Motion Control damper, lockout, tapered steerer, 42 offsetFox Rhythm 36, Float EVOL air spring, GRIP damper, tapered steerer, 44mm offset, Boost110, 15mm KaboltFox Rhythm 36, Float EVOL air spring, GRIP damper, tapered steerer, 44mm offset, Boost110, 15mm KaboltRockShox Lyrik Ultimate, 150 mmFox Factory 36, Float EVOL air spring, GRIP X2 damper, 44mm offset, Boost 110, 15mm Kabolt X axleFox Factory 36, 150 mmRockShox Lyrik Ultimate, DebonAir+ w/ ButterCups, Charger 3.1 RC damper, tapered steerer, 44 mm offset
ShockX-Fusion Pro 2, 2-position damper, 205 mm x 60mmFox Performance Float X, 2-position damper, 205 mm x 60 mmFox Performance Float X, 2-position damper, 205 mm x 60 mmRockShox Deluxe Ultimate RC2TFox Factory Float X, 205mm x 60mmFox Factory Float XRockShox Deluxe Ultimate RC2T, 205 mm x 60 mm
HeadsetFSA Orbit, ZS, 1-1/8 top / 1.5 bottomFSA Orbit, ZS, 1-1/8 top / 1.5 bottom
StemBontrager Comp, 31.8 mm, 7-degree, 35 mm lengthBontrager Elite, 35 mm, 0-degree, 45 mm lengthBontrager Elite, 35 mm, 0-degree, 45 mm lengthBontrager Elite, 35mm, 45mmBontrager Elite, 35 mm, 0-degree, 45 mm lengthBontrager Elite, 35mm, 45mmRace Face Turbine R, 35mm, 0 degree, 40mm length
HandlebarBontrager Comp, alloy, 31.8 mm, 40mm rise, 780 mm widthRace Face Turbine, alloy, 35 mm, 40 mm rise, 780 mm widthRace Face Turbine, alloy, 35 mm, 40 mm rise, 780 mm widthRace Face ERA, carbonRace Face ERA, carbon, 35 mm, 27.5 mm rise, 800 mm widthRace Face ERA, carbonRace Face ERA, carbon, 35 mm, 27.5 mm rise, 800 mm width
GripsTrek Line Comp lock-onTrek Line Comp lock-onTrek Line Elite lock-onTrek Line Elite lock-onTrek Line Elite lock-onTrek Line Elite lock-onTrek Line Elite lock-on
SaddleBontrager Verse Short, stainless steel railsBontrager Verse Short, stainless steel railsBontrager Verse P3, chromoly railsBontrager Verse Short Comp, steel rails, 145mmVerse Short Comp, steel rails, 145 mm widthBontrager Verse Short Comp, steel rails, 145mmVerse Short Pro, carbon rails, 145 mm width
SeatpostTranzX JD-YSI34 dropper, 34.9mm (150 S / 170 M-XL)Bontrager Line Dropper, 34.9mm (150 S / 170 M / 200 L-XL)Bontrager Line Dropper, 34.9mm (150 S / 170 M / 200 L-XXL)Bontrager Line Dropper, 34.9mm (150 S / 170 M / 200 L-XXL)Bontrager Line Dropper, MaxFlow, internal routing, 34.9 mm (150 mm S, 170 mm M, 200 mm L/XL/XXL)Bontrager Line Dropper, 34.9mm (150 S / 170 M / 200 L-XXL)RockShox Reverb AXS, wireless, 34.9 mm (150 mm S, 175 mm M, 200 mm L/XL/XXL)
BrakesShimano 4-piston hydraulic disc, MT4100 lever, MT420 calliperSRAM DB 8 4-piston hydraulic discSRAM DB 8 4-piston hydraulic discSRAM Maven BronzeShimano XT M8220 4-piston hydraulic discShimano XT M8220SRAM Maven Silver 4-piston hydraulic disc
Rear derailleurShimano Deore M6100, long cageSRAM Eagle 70, T-TypeSRAM Eagle 70, T-TypeSRAM Eagle 90, T-TypeShimano XT M8100, long cageShimano XT Di2 M8260, 12-speedSRAM X0 Eagle AXS, T-Type
CrankE*thirteen E*spec Plus, 160 mm lengthSRAM EAGLE 70, 160 mm lengthSRAM EAGLE 70, 160 mm lengthE*thirteen E*spec Plus, 160 mm lengthe*thirteen e*spec Plus, 160mm, 32TSRAM X0 Eagle, 160 mm length
ShiftersShimano Deore M6100, 12-speedSRAM Eagle 70, 12-speedSRAM Eagle 70, 12-speedSRAM Eagle 90, 12-speedShimano XT M8100, 12-speedShimano XT Di2 M8250, 12-speedSRAM AXS pod
CassetteShimano Deore M6100, 10-51, 12-speedSRAM Eagle XS-1270, T-Type, 10-52, 12-speedSRAM Eagle XS-1270, T-Type, 10-52, 12-speedSRAM Eagle XS-1275, T-Type, 10-52Shimano XT M8200, 10-51, 12-speedShimano XT M8200, 10-51, 12-speedSRAM Eagle XS-1295, T-Type, 10-52, 12-speed
ChainShimano Deore M6100, 12-speedSRAM Eagle 70, T-Type, 12-speedSRAM Eagle 70, T-Type, 12-speedSRAM GX Eagle, T-TypeShimano Ultegra/XT M8100Shimano XT M8100SRAM X0 Eagle, T-Type, 12-speed
DrivetrainShimano DeoreSRAM Eagle 70, T-Type, 12-speedSRAM Eagle 70, T-Type, 12-speedSRAM Eagle 90 T-TypeShimano XT M8100, 12-speedShimano XT Di2SRAM X0 Eagle AXS, T-Type, 12-speed
WheelsBontrager Line TLR 30Bontrager Line TLR 30Bontrager Line TLR 30Bontrager Line Comp 30Bontrager Line Comp 30, Tubeless Ready, 6-bolt, Boost110/Boost148, Rapid Drive 108, Shimano Micro Spline freehub, 29"Bontrager Line Comp 30Bontrager Line Pro 30, OCLV Mountain Carbon, Tubeless Ready, 6-bolt, Rapid Drive 108, Boost110/Boost148, 29"
TyresBontrager Gunnison Elite XR, Tubeless Ready, wire bead, 60 tpi, 29x2.40"Bontrager Brevard Pro XR, Tubeless Ready, dual compound, aramid bead, 60 tpi, 29x2.50"Bontrager Brevard Pro XR, Tubeless Ready, dual compound, aramid bead, 60 tpi, 29x2.50"Maxxis Minion DHF front / Maxxis Minion DHR II rearMaxxis Minion DHF 29x2.5'' (front), Maxxis Minion DHR II 29x2.5'' (rear)Maxxis Minion DHF front / Maxxis Minion DHR II rearMaxxis Minion DHF 29x2.5'' (front), Maxxis Minion DHR II 29x2.5'' (rear)
Weight21.92 kg21.08 kg19.73 kg20.1 kg19.58 kg
Price£4,400£5,000£5,500£7,625£7,625£8,075£10,300
Rides similarly
Spot a mistake?
